Dual forward converter schematic diagram
Source: InternetPublisher:风向西瓜 Keywords: Power conversion circuit Updated: 2024/08/19
When a larger output power is required, a dual forward converter circuit with voltage superposition is generally adopted, as shown in the figure. Circuit features: (1) Two forward converter circuits are connected in parallel, T1 and T2 are driven in anti-phase 180o, the power is doubled, the output frequency is doubled, and the ripple and dynamic response are improved; (2) S1 and S2 are connected in series (S3 and S4 are connected in series), and the withstand voltage of the switch tube is halved; (3) The feedback coil is cancelled, V1, V2, VpV4 are all energy feeding paths, which reduces the requirements for the manufacturing process of the transformer; (4) It has a dead zone limitation characteristic, and the two parts of the circuit do not have a common conduction problem, and the reliability is high. Characteristic analysis: Forward: When turned on, the input feeds power to the load, and when turned off, L supplies power to the load. Withstand voltage: Single tube forward, the maximum voltage of the switch tube is 2Uin. Double tube forward: The maximum voltage of the switch tube is Uin. Transformer: The transformer utilization rate is not high (only the first quadrant of the hysteresis loop is used), and a feed coil must be added in the process. Application: Since the dual-tube forward parallel circuit has high output power, doubled output square wave frequency, easy filtering, and half the voltage resistance of the switch tube (approximately the input voltage Ui), it is widely used in high-power conversion circuits and is considered to be one of the main circuits with high reliability and uncomplicated manufacturing.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- 220V Remote Load Monitor
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED rechargeable flashlight circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A small and easy-to-make fast charger
- Integrated regulated power supply with continuously adjustable output voltage
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- Practical constant current charger-----Constant current charger
- Laser power circuit
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- KGDS type single-phase low temperature iron plated power supply circuit
- Super Class A power amplifier power circuit
- Karaoke light controller circuit (1)
- Head amplifier dedicated power supply circuit
- ±15V active servo power circuit
- Practical neon light power circuit
- COMPAQ 420G type SVGA color display power supply circuit
