LTM8045 SEPIC regulator application circuit diagram collection
Source: InternetPublisher:武林萌主 Keywords: Power switching voltage regulator voltage regulator converter Updated: 2020/12/06
The LTM®8045 is a μModule® (miniature module) DC/DC converter that can be configured as a SEPIC or inverting converter by simply connecting the appropriate output voltage rail to ground. In a SEPIC configuration, the regulated output voltage can be higher, lower, or equal to the input voltage. The LTM8045 incorporates power devices, inductors, control circuitry and passive components. The complete design requires only input and output capacitors and small resistors to set the output voltage and switching frequency. Other components can be used to control soft-start and undervoltage lockout.
![12V SEPIC Converter LTM8045 12V SEPIC Converter](http://www.eeworld.com.cn/circuit/upload/d03c483ce2973324ba9faa268d6ae029/8cac32ead158582b79fdab4d38f8c9ce.png)
LTM8045 12V SEPIC converter
![-12V Inverting Converter LTM8045 -12V negative output converter](http://www.eeworld.com.cn/circuit/upload/d03c483ce2973324ba9faa268d6ae029/5d4c380287a7da990e5106c1cbc5b9d6.png)
![-5V Inverting Convener LTM8045 -5V negative output converter](http://www.eeworld.com.cn/circuit/upload/d03c483ce2973324ba9faa268d6ae029/b4864dbc4ea2979037c22f4af5b78c39.png)
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Miniature polarity reversal power supply using MAX1721
- Using CW34603 to form a circuit to change the polarity of the output power supply
- CNC regulated power supply production
- Electric bicycle battery charger circuit
- Car Audio Power Supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- LTM8045 SEPIC regulator application circuit diagram collection
- Switching power supply circuit composition and detailed explanation of each part (1)
- The simplest switching regulated power supply circuit diagram
- High performance GS1662 application circuit
- Power supply circuit with multiple outputs (MAX1902)
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Warm current power circuit a
- Timing switch AC power circuit
- Recording level power supply circuit
- Diamond differential input power amplifier power circuit
