2-phase CPU power circuit using HIP6301 and HIP6601 chips
Source: InternetPublisher:aytwartoofyoroo Keywords: CPU power circuit Updated: 2020/04/05
Shown is a 2-phase CPU power supply circuit using HIP6301 and fflP6601 chips . This circuit uses one H IP 6301
chip as the main control chip in the circuit, and two fflP6601 chips as PWM signal driver chips.
This circuit converts the +5 V power supply into the DC voltage required by the CPU (1.5 V-1.9 V). When the CPU works, it
sends the instruction code of the required voltage value to the VIDO-VID4 of the main chip. The main chip recognizes the instruction code , and then control the phase and pulse width of the PWM signal so that
the final output voltage value meets the requirements of the CPU chip .
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade Electric Bike Fast Charger
- Some notes on electronic design
- Structure of air conditioner horizontal air deflector drive motor and circuit
- Power circuit b composed of intelligent thyristor modules
- Connection circuit between DAC0832 and 8086CPU
- Connection of equalizer and related circuits
- Voltage stabilization control circuit in power circuit
- Output 12V-10A power supply circuit
- Typical computer motherboard CPU power supply circuit
- Voltage stabilizing circuit for CPU power supply circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
