Amplifier circuit diagram
Source: InternetPublisher:sigma Keywords: Audio circuit amplifier circuit diagram mutually asymmetric circuit Updated: 2021/09/29
Amplifier working process and composition principle:
(1)Work flow
Input - preamplifier stage - push stage - OTL power output stage - speaker
(2) Composition principle
①Preamplifier stage (input stage)
The preamplifier stage is a common-emitter amplifier circuit connected by V1 tube, R1, RW2, R2, R3, R4, R5, C1, C2, C3, C4, etc. It adopts a voltage-division current negative feedback bias stabilization circuit.
②Push level
The push stage consists of V2 tube, R6, RW4, R7, R8, R9, V7 tube, V8 tube, RW3, R10, C5, C6, C7, which are connected to form a common emitter voltage divider bias stabilization circuit. It undertakes the task of providing sufficient push current to the power output stage. The push stage power output stage adopts direct coupling method.
③OTL power output stage
The output stage has the task of outputting signal power to the load. It consists of an NPN composite tube composed of V3 and V4 tubes. The PNP composite tube composed of V5 and V6 tubes is quasi-complementary symmetrical with R11, R12, R13, R14, and C8. circuit.
3. Practice making loudspeaker printed circuit board drawings and electrical component layout drawings
4. Practice the component parameters and models of loudspeakers
- 6P3P parallel 20W power amplifier experiment
- TDA2009A power amplifier circuit
- Making a Simple Tube FM Radio
- Toy electronic chicken
- 6C16+FU50 high-fidelity tube amplifier circuit with unique sound
- A very simple amplifier
- Typical applications of optocouplers in audio amplifier circuits
- LM4902 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- LM4820-6 audio power amplifier circuit
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- Audio Dynamic Noise Cancellation System
- Production and debugging of wireless FM microphone
- Design and production of wireless FM microphones
- Amplifier circuit diagram
- Music sound control level indicator circuit diagram
- Practical sound level monitor circuit diagram
- Car steering and reversing audio circuit
- 555 ambulance audio circuit
- Rhythm-changing audio circuit
