Mixer circuit diagram based on LM-1496
Source: InternetPublisher:sigma Keywords: Power supply other power circuits Updated: 2021/10/05
The picture shows the basic LM-1496 mixing circuit. In the figure, the RF and carrier inputs are connected together to form a single-ended structure. The respective signals are sent from the input end through DC blocking capacitors C1 and C2. Each pin is bypassed to ground through capacitors C3 and C4. The output network consists of a 9:1 wideband RF transformer that combines the two outputs and reduces their impedance to 50Ω. The primary coil of the transformer resonates at the intermediate frequency through C5.
![200921495917426.JPG](http://www.eeworld.com.cn/circuit/upload/23baf3a3aaf76b5b28718f73830a672e/eb8ceb36aec47997534fa3ea6afd16ce.jpg)
Figure: Mixer circuit based on LM-1496
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- Visible laser digital control modulation driver
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Detailed explanation of mobile phone charger circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
