Complete electric drag control circuit diagram
Source: InternetPublisher:风向双子座 Keywords: Power communication power Updated: 2021/08/06
Electric drag refers to a method that uses an electric motor to drive the working mechanism of production machinery to make it run. It includes power supply, electric motor, control equipment and transmission mechanism. In order to mechanically complete a certain process, the motor is required to complete different rotation modes according to the process requirements, and a certain type of circuit is used to connect the control equipment to meet the requirements. These circuits are the electric drag control circuits.
It includes: inching circuit, continuous operation circuit, forward and reverse circuit, multi-ground control circuit, step-down starting circuit, multi-speed asynchronous motor control circuit, position control circuit, etc. These are electrical drag control lines.
1. Principle diagram of continuous operation control of electric motor
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/bfd45fc479fcd92e370a981e9e56583a.jpg)
2. Motor inching control principle diagram
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/9ecc804833acb8897fa78fb1651496c6.jpg)
3. Forward and reverse circuit controlled by contactor
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/bc9bbfeb3cbe760c54fb74c3edd97646.jpg)
4. Double interlocking forward and reverse control circuit
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/a357640b97867f9d052086925136f068.jpg)
5. Automatic round-trip control circuit schematic diagram
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/b69eeacbe5b6261d55e1262e9c4155a3.jpg)
6. Multi-location control
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/77eca087140bd204915e23af04d67603.jpg)
7. Sequence control - start first and then stop
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/0a701203a2a4bc4c8596828204568650.jpg)
8. Sequence control—first start, first stop
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/823d476b02334d632b541e8961e62587.jpg)
9. Three-phase cage asynchronous motor stator winding string resistance starting
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/cc595bf6c7cb8c365a269e4209c9fd12.jpg)
10. Y-△ voltage reduction starting control
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/b219f85be29e4f10d23f9cb730678521.jpg)
11. Autotransformer step-down start
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/ffd567fc1bacbba849598a7b0a2bd880.jpg)
12. Schematic diagram of motor braking control circuit
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/55aee80b46671c15f71ceae071bec337.jpg)
13. One-way reverse braking control circuit
![Complete electric drag control circuit diagram](http://www.eeworld.com.cn/circuit/upload/5b69304b9a13d971e835bd898b6675b1/2be5bf73525938113be212c36265d37e.jpg)
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED rechargeable flashlight circuit diagram
- Detailed explanation of 5v charger circuit diagram
- A simple positive and negative power supply circuit
- Integrated regulated power supply with continuously adjustable output voltage
- LM317 regulated power supply
- Car Audio Power Supply
- Practical constant current charger-----Constant current charger
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Simple dual-channel variable DC power supply circuit
- Diamond differential input power amplifier power circuit
- audio power circuit
- AC-DC conversion power supply-inverter power supply circuit
