LTC2053 thermocouple amplification circuit diagram
Source: InternetPublisher:sigma Keywords: Amplifiers power supplies and other power circuits Updated: 2021/11/15
The amplifier LTC2053 amplifies the output mv model of the thermocouple. Since the LTC2053 works on the sampled input signal, the frequency of interest is generally lower than a few hundred Hz. In this way, adding a 0.1 fog capacitor C1 in the feedback circuit can speed up the response of the amplifier. . Capacitors C2 and C3 connected to the thermocouple input network help absorb radio frequency interference and suppress interference in the thermocouple probe.
Sampling interference occurs. Resistors R6~R9 connected in the thermocouple provide high impedance bias, which maximizes the interference immunity of the probe without voltage drop. Short thermocouples minimize common-mode signals and allow the probe node to be grounded. The 5.1V voltage regulator tube VD1 forms a power supply protection circuit, which prevents overvoltage of the power supply and reverse polarity of the 6V battery. R3 is a current limiting resistor. The working principle of a thermocouple is to generate a potential difference based on the temperature difference between the hot end and the cold end. Since the temperature of the cold end is often not 0°C during actual measurement, the thermocouple needs to be temperature compensated.
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Use pulse width modulation to get a precise output voltage
- Switching power supply circuit composition and function introduction of each part
- Current/voltage conversion circuit using current converter
- LM317 regulated power supply
- Electric bicycle battery charger circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
