Wide range peak detector
Source: InternetPublisher:三月小雨 Keywords: Power supply other power circuits Updated: 2020/03/23
IC1 and IC2 form an inverting half-wave precision rectifier and peak detector circuit. The negative input signal floats with the peak value, which is greater than the C1 voltage, causing the capacitor to be charged to a new peak voltage. The capacitor maintains this voltage until larger signal peaks occur.
- How about the boost converter TPS61299?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Fabrication of multi-cell lithium battery charging circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Dual forward converter schematic diagram
- Design of electric vehicle charger
- Car Audio Power Supply
- A low-cost, high-reliability battery charger for electric vehicles
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
