Two thousand minute timer schematic diagram
Source: InternetPublisher:天天都吃好吃的 Keywords: Power supply other power circuits Updated: 2021/08/04
A CD4020B divider is used to separate the 555 timer frequency in the two thousand minute timer schematic diagram. S1 is a range selector switch that provides time intervals from 2 to 20 minutes, 20 to 200 minutes, and 200 to 2000 minutes. Two thousand minute timer schematic diagram:
![Two thousand minute timer schematic diagram](http://www.eeworld.com.cn/circuit/upload/21201b0b8ae6d5088bc65d4fe6552f7d/fd84d462b7b37076b9fa9534399f3b21.jpg)
- How about the boost converter TPS61299?
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Op amp power supply decoupling bypass measures
- Driving circuit that controls LED brightness using PWM signal
- 0.7~24V continuously adjustable current limiting power supply
- Production of backup power supply for cordless phone
- Car Audio Power Supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Detailed explanation of mobile phone charger circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
