A flasher circuit connected directly to a 220V power supply
Source: InternetPublisher:天天都吃好吃的 Keywords: Flash light circuit Updated: 2024/06/03
This is a 220V 800W flasher light circuit that connects directly to a 220V mains supply. One or more lights with high consumption/power can be used. It is ideal for sign warnings or dangers, this circuit makes the light flash.
The working of this circuit is very simple. The 400V capacitor, bridge rectifier, Zener diode and 100uF capacitor will form a supply voltage obtained of approx. 9VDC from a transformerless power supply design. The integrated 555 and its accessory components produce a series of pulses applied to the triac optocoupler MOC3021, which is driven intermittently, causing the light to turn on and off continuously. The triac can be 2N6073A or TIC226D. By changing the 100K resistor or 1uF capacitor, the flashing time will also change. The rectifier bridge can be 4 1N4007 diodes or a 400V bridge diode with a current of 1A. The triac should be mounted on a heat sink to prevent overheating.
WARNING!!! The entire circuit is powered by a 220v mains supply without insulation, so proper safety precautions should be taken to minimize the risk. Build this 220V 800W flasher circuit at your own risk.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- What is a RADAX motor?
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Using P110C to control 6 DC motors simultaneously
- Simple phase failure protection circuit composed of intermediate relay
- Ultra-short wave item left behind reminder alarm
- Precious home appliance anti-theft alarm
- 13 examples of electric drag control circuit diagram
- Rural fish farming control circuit
- Egg heating control circuit
- Stapler control circuit
- Electromagnet control circuit
- Humidity detection box control circuit in greenhouse
- Sprinkler control circuit using AC motor
- Temperature detection control circuit of electric kettle
- Micro DC motor steady speed control circuit a
- Wide input range non-synchronous voltage mode control circuit
