Two drive circuits for separately excited piezoelectric loudspeakers and piezoelectric vibrating plates
Source: InternetPublisher:aytwartoofyoroo Keywords: Power supply other power circuits Updated: 2021/05/30
Separately excited piezoelectric amplifiers and piezoelectric diaphragms vibrate by applying AC voltage between the two terminals of the product. Taking the standard driving circuit example as an example, there are two methods, (1) using transistor circuits and (2) driving directly through a microcomputer.
(1) When using a transistor circuit
![When using transistor circuits](http://www.eeworld.com.cn/circuit/upload/086aacd80c4dc112a6b598ed47aa39b7/dc2429a1339199bb0b6c9acd88e8253a.png)
Examples of driving circuits for piezoelectric speakers and piezoelectric vibrating plates (separately excited type) using transistor circuits
The greater the voltage value applied to V, the greater the sound pressure of the piezoelectric sound element. Therefore, it is widely used when the power supply (voltage) can be ensured to be higher than the driving voltage of the microcomputer.
For the circuit components in the figure, add the following:
Rp in the diagram is essential to release the charge stored in the piezoelectric sound-generating element, so be sure to use it. Rs is for volume adjustment, please use it when needed.
When protecting the IC from the reverse voltage of the piezoelectric sounding element, the transistor becomes a buffer, but for the protection of the transistor itself, if necessary, please also consider using a Zener diode in parallel with the piezoelectric sounding element and Rp.
FETs can also be used instead of transistors.
(2) When driven directly by microcomputer
![When driven directly by microcomputer](http://www.eeworld.com.cn/circuit/upload/086aacd80c4dc112a6b598ed47aa39b7/1434ce66fb79861edb7532a00f466ccc.png)
Example of driving circuit for piezoelectric loudspeaker and piezoelectric diaphragm (separately excited type) when driven directly by microcomputer
Electronic sound components have high impedance and are voltage driven, so they can be driven directly by ICs.
In order to protect the IC from damage by the reverse voltage of the piezoelectric sound element, if necessary, please also consider using a Zener diode in parallel with the piezoelectric sound element.
Please adopt a circuit design that avoids applying DC voltage to piezoelectric sound components for a long time.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Single-power supply circuit for ISO122P/ISO124
- Current/voltage conversion circuit using current converter
- Charging control circuit made by solar energy
- Homemade low-power UPS
- CNC regulated power supply production
- Adjustable voltage power socket
- MIC4680 constant current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
