Differential bridge amplifier circuit diagram
Source: InternetPublisher:fish001 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/05/29
The LTC2050HV is a zero-drift operational amplifier available in 5-pin or 6-pin SOT-23 and SO-8 packages. The LTC2050 operates from a single 2.7V to 6V power supply.
The following is a circuit diagram of a differential bridge amplifier.
![Differential bridge amplifier circuit diagram](http://www.eeworld.com.cn/circuit/upload/96457ed9ad0177fd0123abe01977a777/8ef7745b12923c18a91881b04d4db73b.jpg)
The LTC2050HV operates from a 2.7V to ±5.5V power supply. Current consumption is 800µA, and power-down functionality (active low) is available on versions of the device in 6-pin SOT-23 and SO-8 packages. Although the LTC2050 is small in size, its DC performance is not compromised at all.
Typical input offset voltage and offset drift are 0.5μV and 10nV/C respectively. Nearly zero DC offset and drift are supported with power supply rejection ratio (PSRR) and common mode rejection ratio (CMRR) greater than 130dB.
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Build a simple buck-boost regulator and test it on a breadboard
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Introduction and principle analysis of switching regulated power supply
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Op amp power supply decoupling bypass measures
- 3~15V 10A adjustable voltage regulated power supply
- Car Audio Power Supply
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
