LTC2053 thermocouple amplification circuit diagram
Source: InternetPublisher:刘德华河北分华 Keywords: RF power and other power circuits Updated: 2023/12/12
The amplifier LTC2053 amplifies the output mv model of the thermocouple. Since the LTC2053 works on the sampled input signal, the frequency of interest is generally lower than a few hundred Hz. In this way, adding a 0.1 fog capacitor C1 in the feedback circuit can speed up the response of the amplifier. . Capacitors C2 and C3 connected to the thermocouple input network help absorb radio frequency interference and suppress interference in the thermocouple probe.
Sampling interference occurs. Resistors R6~R9 connected in the thermocouple provide high impedance bias, which maximizes the interference immunity of the probe without voltage drop. Short thermocouples minimize common-mode signals and allow the probe node to be grounded. The 5.1V voltage regulator tube VD1 forms a power supply protection circuit, which prevents overvoltage of the power supply and reverse polarity of the 6V battery. R3 is a current limiting resistor. The working principle of a thermocouple is to generate a potential difference based on the temperature difference between the hot end and the cold end. Since the temperature of the cold end is often not 0°C during actual measurement, the thermocouple needs to be temperature compensated.
- An example of LC oscillation circuit
- DC negative high voltage generator
- Duty cycle adjustable multivibrator circuit composed of MC14574
- Field effect transistor RC bridge oscillation circuit
- Inexpensive high-precision digital clock time base circuit
- 1kHz to 1MHz sinusoidal oscillator circuit
- Magnetic pendulum oscillation circuit
- RC bridge oscillator and its equivalent circuit
- Variable start/stop ramp oscillator
- 800Hz single transistor oscillation circuit
- Car sales fell in September, followed by new energy vehicles
- About the real-life application of Silicon Labs’ new isolation smart switch
- Determining the prerequisites for successful circuit board design
- Automotive electronic fuel saver circuit diagram and principle
- What’s so magical about the main circuit inside the inverter?
- Humidity detection circuit schematic diagram
- Current extension circuit diagram with bipolar output
- Single Supply Op Amp Applications
- Ruidike PHS mobile phone RF front-end design circuit diagram
- MC145026 (general) infrared, ultrasonic or radio frequency remote control transmission encoding circuit
