Automatic telephone call recording circuit
Source: InternetPublisher:无人共我 Keywords: Power communication power Updated: 2020/02/28
![Automatic telephone call recording circuit](http://www.eeworld.com.cn/circuit/upload/faa78b7411bf4d05f4baff1bc39ea4b2/038497e8ac4b0552830642dc18119f36.gif)
DC voltage on telephone lines is currently typically around 45 to 50V, with 6V on-hook and off-hook. This circuit uses a step-down activated relay. Relay controls tape recorder. Audio is via network to tape microphone input.
- Build a simple buck-boost regulator and test it on a breadboard
- 220V Remote Load Monitor
- Fabrication of multi-cell lithium battery charging circuit
- Step-down power supply for driving relays
- What kind of circuit is a voltage regulator circuit?
- Op amp power supply decoupling bypass measures
- Transformerless AC-DC constant current LED driver circuit
- The constant current source composed of two transistors can drive high power
- Boost drive circuit composed of RT8450
- UC3842 Electric Vehicle Charger
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Simple dual-channel variable DC power supply circuit
- Diamond differential input power amplifier power circuit
- audio power circuit
- AC-DC conversion power supply-inverter power supply circuit
