Automatic switching control circuit for two parallel transformers
Source: InternetPublisher:toothache Keywords: Power supply regulated power supply Updated: 2020/12/23
![Automatic switching control circuit for two parallel transformers](http://www.eeworld.com.cn/circuit/upload/96549ab0a7f14c0f3c5ee3d330d8c4ba/ecd0d7575c16bcec7df2e93bae9d9c8d.gif)
In order to make the transformer operate economically, it is often necessary to put in or cut off the transformers operating in parallel according to the change of the load. For this purpose, the automatic switching control circuit as shown in the figure can be used.
First, calculate the economic operating points of the two transformers, and then convert it into the corresponding load current Ij based on the capacity at the economic operating point. When the load current is less than Z}, withdraw one transformer and leave only one operating}. When the load current is large When dry, both transformers are put into operation.
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- What kind of circuit is a voltage regulator circuit?
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Use pulse width modulation to get a precise output voltage
- The constant current source composed of two transistors can drive high power
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- MAX1811 Lithium Battery Charger Production
- Power circuit of STR5412
- Three-way DC-DC converter circuit
- Commonly used power circuits in printers
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Timing switch AC power circuit
- Karaoke light controller circuit (1)
- Household emergency power circuit 02
- Antenna amplifier synchronous power supply circuit
- Telephone power circuit
- High quality power supply circuit schematic diagram
