SPICE Hysteresis Modeling Solution
Source: InternetPublisher:toothache Keywords: SPICE linear model Updated: 2024/08/06
This article presents a technique for constructing a standard SPICE model that is able to model the essential characteristics of systems with continuous hysteresis.
The example model in this article shows adding a high-frequency sine wave offset to an audio signal to reduce signal distortion on an analog tape recorder. This technique allows for a sufficiently accurate approximation to illustrate the distortion created by hysteresis and how it can be reduced by adding a high-frequency offset.
Hysteresis Model
The essential problem with modeling hysteresis is that it is a static or DC effect with memory. That is, the next value depends not only on the current value, but also on the previous value. However, this last value dependency does not depend on time. This results in a multi-valued transfer function.
Unfortunately, standard SPICE does not directly support this type of modeling. All reliance on the last value in SPICE is usually the result of a linear integration, which inherently leads to a frequency-dependent transfer function and does not take into account the distortion mechanisms.
One way to solve this problem is to simply realize that one can cheat. Analog models only need to do approximately what they need to do over a limited frequency range. Analysis shows that a small capacitor combined with a nonlinear diode resistance can be used to continuously store the last value of the signal before it changed slope direction to provide effective hysteresis, but without excessive dependence on frequency.
This is in contrast to some SPICE "hysteresis" models which only have two output state models and do not allow for a continuous transfer function.
Linear Model
The following schematic forms the basis of a continuous hysteresis model that can be used to model; for example, a magnetic core.
Note that the output voltage here is multi-valued but essentially linear beyond the dead zone. The dead zone occurs when the signal changes direction. It can be adjusted by the diode parameter N.
Figure 1. Schematic diagram of the continuous lag model
The output voltage of this module essentially follows the input linearly, but with an offset voltage. When the input is reversed, the capacitor holds the voltage so that there is a dead band from the peak voltage reached.
The key principle of operation is the presence of a nonlinear impedance that has a sharp resistance ratio under forward and reverse bias conditions. The standard diode equation is the simplest, but not essential, equation for this technique. It is used here to illustrate the method.
Substitution equations can be used to fine tune the response characteristics. The input voltage can also be further processed to obtain different nonlinear transfer curves. The example here uses the behavioral model of a diode:
b1 aci={is}*(exp({k}*v(a,c)) - 1)
To obtain an accurate model, the values of the components are chosen so that the frequency effects are minimized over the frequency range in which you wish to model the system.
The time constants of R load and C memory are such that the last voltage before the turn around does not leak too much. The charging current through the driven impedance (i.e. the diode in this particular case) does not limit the response of the system over the desired operating frequency range.
The above topology produces the following set of transfer functions and hysteresis plots for various input voltages and frequencies:
Figure 2. Ramp Input Transfer Function - F=1KHz, VIN=2V, 4V, 6V, 8V, 10V
Figure 3. Ramp Input Transfer Function - F = 1MHz, VIN = 2V, 4V, 6V, 8V, 10V
Figure 4. Hysteresis - F=1kHz, VIN=2V, 4V, 6V, 8V, 10V
Figure 5. Hysteresis - F=1MHz, VIN=2V, 4V, 6V, 8V, 10V
The key point of the graph is that over a frequency range of 1000:1, the voltage transfer function and hysteresis voltage are relatively constant, thus providing a good approximation of true DC hysteresis.
Typically, one constructs a SPICE behavioral resistor from a controlled current source with the desired forward and reverse characteristics. For example, as we pointed out above, the hysteresis deadband voltage can be adjusted by changing the diode parameter “N” from its default value of “1”.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Analysis of the basic principle of measuring resistance by bridge method
- How to read resistor color codes? Resistor color codes illustrated
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Working principle/advantages/disadvantages/size of optical fiber
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Structural diagram and function of sliding resistor
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
