RF sniffer circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Power communication power Updated: 2020/07/07
The circuit responds to RF signals below standard broadcast bands and above 500MHz, providing visual and audible indications when a signal is received. By adjusting the bias of the pick-up diodes D1 and D2, this circuit can be used to receive low power signals as well as strong energy sources. Carefully adjust R2 until the LED starts to glow and emit a faint sound produced by the piezoelectric sounder, and you have a very sensitive setting.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- In-depth analysis of DC-AC converter inverter
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- Charging control circuit made by solar energy
- Power supply circuit that can reduce LM317 ripple
- Adjustable voltage power socket
- Constant current charger using light emitting diode as voltage regulator
- The production of adjustable voltage-stabilized power supply composed of LM317
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Simple dual-channel variable DC power supply circuit
- Diamond differential input power amplifier power circuit
- audio power circuit
- AC-DC conversion power supply-inverter power supply circuit
