10A output 1-5V low voltage high current converter
Source: InternetPublisher:通通 Keywords: power supply buck current converter Updated: 2021/02/28
(1) Input working power supply voltage is 5V.
(2) The 0.8V reference source inside the chip has an accuracy of ±1.5% within all linear adjustments, load adjustments and temperature ranges.
(3) The output voltage range is 0.8V~VCC.
(4) The duty cycle adjustment range is 0~100%.
(5) It has the internal loop compensation function of the chip.
(6) It has a soft start function, and its typical soft start time is 2ms.
(7) It has over-current protection function. In order to reduce costs, the current sensing resistor can use the on-resistance RDS of the MOSFET power switch.
(8) It has under-voltage protection and shutdown control functions.
(9) Can drive external N-MOSFET power switch.
(10) It has a very space-saving SOP-8 type package.
(11) Product series with operating junction temperature ranging from 0 to 125°C are available.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- ISO113 circuit that can reduce power consumption
- Use pulse width modulation to get a precise output voltage
- Switching power supply circuit composition and function introduction of each part
- How to use SBR to improve power conversion efficiency
- 0.7~24V continuously adjustable current limiting power supply
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- How to Select TVS Diodes in Hot Swap Applications
- How to choose power supply filter capacitor?
- Redefine camera power modules with scalable PMIC simplified design
- How to use PA power analyzer to perform a perfect test on the power supply?
- To optimize battery charging, Apple introduces new power management features in macOS
- Which power supplies should be chosen for collection?
- For Schottky rectification, what are the advantages of synchronous rectification?
- Medical infusion alarm circuit
- Li-ion battery charger composed of MAX1757
- Rotor, stator and drive circuit of brushless motora
