ISO113 circuit that can reduce power consumption
Source: InternetPublisher:已注销 Keywords: Isolation circuit Updated: 2024/09/18
The figure shows the power-saving ISO113 circuit. For single-channel or multi-channel synchronous applications requiring VCC1 current less than ±15mA, an oscillator can be used to generate TTL level to drive the synchronous input terminal (pin ③) and the enable terminal (pin ①) to reduce power consumption.
- Practical and convenient fax machine power supply control circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- LED Driver ZD1680
- Current/voltage conversion circuit using current converter
- CNC regulated power supply production
- Adjustable voltage power socket
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- LM317T voltage regulation adjustable circuit diagram explanation
- Design of adjustable DC stabilized power supply circuit module
- Power circuit with smoothing filter capacitor
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Single phase thyristor slotless nickel plated power circuit
- Class A power amplifier power circuit
- DC power supply circuit for semiconductor radio
- Common power circuits and applications 01
- Inverter power circuit made with BJ50A
- ±5V, ±12V power circuit A
- Maintenance and experiment of multi-purpose power circuits
