Multifunctional battery charger
Source: InternetPublisher:qoistoochee128 Keywords: Power charging circuit Updated: 2020/06/06
The LM317 voltage regulator forms a constant current source to provide 50mA charging current for the S01-S06AA battery box array. Each battery box is connected in series with the LED and is connected to a shunt resistor. When the battery case contains a battery, the LED lights up during charging. Each battery box is connected in parallel with the LED through a 5.1V zener tube.
- The basic principles of power supply design. What are the key components of a power supply?
- Schematic diagram of car cigarette lighter to USB power port
- ISO113 circuit that can reduce power consumption
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Constant current LED lamp driver circuit with soft start and anti-shock
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Homemade Electric Bike Fast Charger
- LM317T voltage regulation adjustable circuit diagram explanation
- variable gain amplifier
- Lead-acid battery charger circuit schematic diagram
- Power supply circuit design optimized for digital light projectors
- Power circuit a composed of intelligent thyristor modules
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Single phase thyristor slotless nickel plated power circuit
- ±15V active servo power circuit
- Common power circuits and applications 07
- Common power circuits and applications 04
- Common power circuits and applications 01
