Remote control circuits for lamps or other applications
Source: InternetPublisher:拿铁三分糖 Keywords: Power supply other power circuits Updated: 2021/02/15
This circuit uses the raw current from a small 6.3V filament transformer to drive a triac and provide energy to the load. When switch S1 is in the 6V secondary winding of the transformer, a small magnetizing current flows through the primary winding. This magnetizing current may be large enough to trigger the triac. Therefore, a shunt resistor R1 needs to be used to prevent triggering from occurring.
- Analysis of the working principle of switching regulator
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Build a simple buck-boost regulator and test it on a breadboard
- Fabrication of multi-cell lithium battery charging circuit
- Introduction and principle analysis of switching regulated power supply
- Boost drive circuit composed of RT8450
- A novel and practical DC low voltage stabilized power supply
- CNC regulated power supply production
- Converting a lithium battery charging board into a constant voltage and current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
