Low drift peak detector
Source: InternetPublisher:通通 Keywords: Amplifier power supply stabilized power supply Updated: 2020/01/28
This circuit uses operational amplifier U1 to compensate for the offset of peak detection diode D1. Ch is the exact peak voltage, and U2 is the voltage follower used to read the voltage.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- A very convenient small power supply circuit to share
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable voltage power socket
- Electric bicycle battery charger circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Essentials of making a tube amplifier
- Making a 6N7P Class B power amplifier circuit
- Commonly used sensing circuits
- Active load differential amplifier circuit diagram
- Basic Op Amp Differential Amplifier
- Single Supply Op Amp Applications
- non-diode rectifier
- Low drift peak detector
- Infrared remote control transmitter/receiver circuit
- High frequency impedance matching amplifier
