Bad books do not bind circuits
Source: InternetPublisher:睡不醒的小壮 Keywords: Power supply other power circuits Updated: 2021/02/24
![Bad books do not bind circuits](http://www.eeworld.com.cn/circuit/upload/06f592e33f25ebb8372665e83d6ddcdf/9e08f36ce8d4e9344c208cb8bf3f447f.gif)
In the bad book unbinding circuit shown in the figure above, YV1 is the execution solenoid valve that controls the machine head to unbind bad books. Under normal circumstances without a bad book signal, the left tube VTI of the bistable trigger is cut off, and the right tube VT2 is turned on, and the collector voltage of VT2 is ov at this time. If a bad book signal enters the flip-flop, the flip-flop flips, and its state is that the left tube VT1 is turned on, the right tube VT2 is turned off, and the collector voltage of vri is +9 .5V. This signal is amplified by current VI'3, and controls VT4 to conduct, causing relay Kl to close, and electromagnetic valve YV1 to act, controlling the machine head not to bind bad books.
- In-depth analysis of DC-AC converter inverter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- Adjustable regulated power supply with current limiting protection
- USB power socket using the car battery
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
