Variable pulse width circuit
Source: InternetPublisher:拳制龙 Keywords: Power supply other power circuits Updated: 2020/01/20
R1 and C2 together provide a wide range of pulse widths from the Motorola MC851P mono line. The rise and fall times of the supplementary output pulses are greater than 100μs. As long as four conversion capacitors are used in conjunction with R1, the pulse width can vary within the maximum range of 4.5ms and the minimum range of 4.5μs.
- Sharing layout and tips for multi-rail power supply design
- The basic principles of power supply design. What are the key components of a power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- 220V Remote Load Monitor
- Constant current LED lamp driver circuit with soft start and anti-shock
- Parallel DC regulated power supply circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A small and easy-to-make fast charger
- A novel and practical DC low voltage stabilized power supply
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
