Pulse width modulated mono circuit
Source: InternetPublisher:常思一二 Keywords: Power supply other power circuits Updated: 2020/03/05
This circuit provides pulse width modulation with high duty cycle and complementary outputs. The flash input of G1 drives the gate output of the double zero circuit, turning off Q1. The voltage then passes through C1, the single junction transistor Q3 emits light, and then C1 discharges. The output of the single-junction transistor drives the output of G2 to a double-zero circuit.
- The basic principles of power supply design. What are the key components of a power supply?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- 3~15V 10A adjustable voltage regulated power supply
- 0.7~24V continuously adjustable current limiting power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade Electric Bike Fast Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
