Stepper motor drive circuit composed of LB1836M
Source: InternetPublisher:小胖友 Keywords: Microcontroller power supply and other power circuits Updated: 2020/02/18
![Stepper motor drive circuit composed of LB1836M](http://www.eeworld.com.cn/circuit/upload/397b0e4c4af41888d31a57ad3f096c9c/571d3d4d839551471d5f8d440441c561.jpg)
In this cable material, pins INl, IN2, IN3 and IN4 are the input terminals of the step pulse. OUT1, OUT2, OUT3, and OUT4 are the output terminals of step pulses, which are connected to the corresponding A, NA, B, and NB of the motor in the thermal print head respectively. The logical relationship between OUT[1:4] and IN[1:4] is OUT=IN. The output drive voltage is controlled by the pin VS. Its voltage determines the working current of the stepper motor, affects the speed of the stepper motor, and determines the speed of paper feeding. The four step pulses at the input terminal of LBl836M can be generated by the four PWM channels of PWM0, PWMl, PWM2 and PWM3 of the microcontroller. The phase relationship of the four-channel PWM is that PWM0 and PWM2 are inverted, PWMl and PWM3 are inverted, and the phase difference between PWM0 and PWMl is π/2. Stepper motor drive circuit composed of LB1836M:
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- Simple and practical LED lamp driving circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A simple positive and negative power supply circuit
- A novel and practical DC low voltage stabilized power supply
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Adjustable voltage regulated power supply circuit
- Design of temperature detection circuit implemented by single chip microcomputer
- Teach you a reliable new method to implement overvoltage protection for electronic signal inputs
- Vishay FRED Pt® ultra-fast recovery rectifier launched on the market
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- About star-delta step-down start plc ladder diagram circuit diagram
- About the working principle of single touch mode light switch
- Minimum system interface circuit based on AT89C52 microcontroller
- Microcontroller measurement circuit
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- Interface between serial IO port AD converter and microcontroller
