Control circuit diagram of demagnetization switch using CD2-G type
Source: InternetPublisher:睡不醒的小壮 Keywords: Switch control power supply DC/DC Updated: 2021/06/11
Today’s article introduces a demagnetization switch control circuit using the CD2-G type. As shown in the figure below, KMi is the closing contactor; YA is the closing coil; YRi and YRz are the trip coils; SQi~SQs are the terminal switches; SA, KT, Hi, Hz are the same as before. The automatic demagnetizing contactor KMz is used to connect the demagnetizing resistor in the exciter rotor circuit during demagnetization.
![Control circuit diagram of demagnetization switch using CD2-G type](http://www.eeworld.com.cn/circuit/upload/2b07dcde5e440499a22d67ecd66223d3/06d380d4bf8d9439758ec0403b808f50.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- Use pulse width modulation to get a precise output voltage
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED Driver ZD1680
- LNK304 non-isolated LED light string driver circuit
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- LM317 regulated power supply
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Contact switch or proximity sensor circuit
- Clock switching circuit and its precautions
- DC/DC converter circuit diagram of primary ZVS and secondary ZVS synchronous rectification controlled by ISL6752
- Parallel power op amp
- A simple DC LED driver circuit
- Control circuit diagram of demagnetization switch using CD2-G type
- Electric kettle automatic power off controller circuit diagram
- Power circuit a composed of intelligent thyristor modules
- A single-connection switch controls a light and is connected to an additional outlet
- Two single-link switches control two lights
