Contact switch or proximity sensor circuit
Source: InternetPublisher:明天见 Keywords: Sensors switches power supplies DC/DC Updated: 2021/06/21
This circuit is started by adding capacitance between the two sensing electrodes and the ground end of the wire. Sensitivity can be adjusted appropriately when the human body is within one foot of the insulating metal plate, which acts as a sensing electrode. So, the sensitivity can be adjusted with a 1 million ohm potentiometer which prioritizes the anode voltage over the clamping voltage.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Driving circuit that controls LED brightness using PWM signal
- LED Driver ZD1680
- LNK304 non-isolated LED light string driver circuit
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- USB power socket using the car battery
- Practical constant current charger-----Constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- How the acceleration sensor works
- Multiple input light sensors
- Contact switch or proximity sensor circuit
- Reasons why the Hall switch element does not work
- Blood pressure sensing circuit diagram of BP01 pressure sensor
- Soil drying alarm circuit
- Thermocouple Thermometer Circuit
- Electric guitar effect enhancement circuit
- Sensor bridge circuit diagram
- Microcomputer circuit compatible with sensor
