Multifunctional conductivity tester circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: Diodes power supplies and other power circuits Updated: 2021/11/27
![Multifunctional conductivity tester circuit](http://www.eeworld.com.cn/circuit/upload/ae1ff567ed39bc9892009d2b1b57e709/15428633b62b669e0055b1a92e0b9d55.jpg)
The circuit of the multifunctional conductivity tester is composed of a detection electrode, a resistor divider, a buffer circuit and a two-color diode, as shown in the figure. The detection electrode can sense the resistance of the object being measured, and control the two-color light-emitting diode to emit light according to the resistance of the object being measured. When the detection electrode senses that the resistance of the object being measured is greater than 300kΩ and less than 1000kΩ, the green indicator light turns on; when it senses that the resistance of the object being measured is less than 300kΩ, the red indicator light turns on, making the two colors synthesize into an orange-red light; when it senses that the resistance of the object being measured is greater than 1000kΩ , the two-color indicator lights VL3 and V⒕ do not light up. Adjusting the potentiometer RP can change the sensing range of the detection electrode.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- A very convenient small power supply circuit to share
- Schematic diagram of car cigarette lighter to USB power port
- Detailed explanation of 5v charger circuit diagram
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- Car power 1.5V-12V six-speed converter
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade Electric Bike Fast Charger
- Schottky and Silicon Carbide Diode Analysis
- Analog Circuit--Miscellaneous Talk on Rectification
- Acousto-optic digital level detector circuit diagram
- Analysis of various power supply filter circuits
- Intrinsically protected safety op amp
- Mobile phone shielding circuit that can be used as a charger
- Diode balanced amplitude modulation circuit
- Thyristor cut-off delay circuit 6
- Internal structure of MC1411 series Darlington current drivera
- Fast response circuit a when controlled by transistor
