A diesel engine thyristor voltage regulating circuit diagram
Source: InternetPublisher:两手空空 Keywords: Power supply other power circuits Updated: 2020/12/29
Today we introduce a diesel engine thyristor voltage regulation circuit diagram. It uses JFT201A voltage regulator. When starting the diesel engine, the key switch SA connects contacts 1 and 2, press the start button SB, the main contact of the electromagnetic switch closes, and the motor M starts to run, driving the diesel generator GS to start. When the machine terminal voltage reaches the rated value, the voltage regulator tube VS breaks down, the transistor VTi is turned on, VT2 is cut off, and the excitation is interrupted, so the generator terminal voltage drops. When it drops to the specified value, VS no longer breaks down, VTi is cut off, VTz is turned on, supplying excitation, and the output voltage increases again. Repeat the above process to maintain the generator output voltage within the specified value range. Adjusting the potential RP can change the output voltage setting value of the generator. As shown below.
![A diesel engine thyristor voltage regulating circuit diagram](http://www.eeworld.com.cn/circuit/upload/b27ee76a09b8f9a6b051154bb9205812/c914a0166bbadbd228511c5c47f2b0bb.jpg)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Benefits of Wide Bandgap Technology for Power Converters
- In-depth analysis of DC-AC converter inverter
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Adjustable voltage power socket
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
