Photoelectric control electronic birthday cake circuit
Source: InternetPublisher:Lemontree Keywords: Diodes power supplies and other power circuits Updated: 2020/10/12
Shown is the circuit of a typical photoelectrically controlled electronic birthday cake. In the figure, VD1 is a photosensitive diode, and IC1 is a control circuit, which is a music chip. When the switch S is turned on and the candle is lit to illuminate VD1, the voltage at pin ② of IC1 drops, and pin @ outputs the control voltage. The music chip works and outputs a music signal to drive the buzzer. The instrument makes a sound.
![Photoelectric control electronic birthday cake circuit](http://www.eeworld.com.cn/circuit/upload/513b1fc6015d3398a5afe338337ba99b/1555ffb81e18f5e13c26d4b4e1d6d204.gif)
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- ISO113 circuit that can reduce power consumption
- Recommended circuits for different power on times of LM4911
- Principles and precautions of active discharge circuit
- Boost drive circuit composed of RT8450
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Electric bicycle battery charger circuit
- Schottky and Silicon Carbide Diode Analysis
- Analog Circuit--Miscellaneous Talk on Rectification
- Acousto-optic digital level detector circuit diagram
- Analysis of various power supply filter circuits
- Intrinsically protected safety op amp
- Mobile phone shielding circuit that can be used as a charger
- Diode balanced amplitude modulation circuit
- Thyristor cut-off delay circuit 6
- Internal structure of MC1411 series Darlington current drivera
- Fast response circuit a when controlled by transistor
