Capacitance measuring instrument circuit
Source: InternetPublisher:走马观花 Keywords: Measurement power supply and other power circuits Updated: 2020/09/30
![Capacitance measuring instrument circuit](http://www.eeworld.com.cn/circuit/upload/60ed1d9f807102346a78a304fe4a6dc6/a6a8274e69f875910e3f0b44f735a878.jpg)
Transfer files for PCB proofing
This measuring instrument can measure capacitance from several pF to 0.1uF, and the range is divided into five levels: 25pF, 100pF, 1000pF, 0.01uF and 0.1uF. Since the measurement principle is linear, it can be read directly using the ammeter scale.
When VT4 is turned on, the measured capacitor Cx and diode VD discharge. When VT4 switches once, the measured capacitor is charged and discharged once. The capacitance being measured is large, and more electricity passes through the ammeter each time it is charged; in addition, VT4 switches more times per second, and more electricity passes through the ammeter per second. The amount of electricity passing through the ammeter per second is the current flowing through the ammeter. Therefore, the current through the ammeter is proportional to the capacitance being measured, and proportional to the switching frequency of VT4. If the current passing through the ammeter is required to be the same, then the switching frequency of VT4 must be higher when measuring small capacitors.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- The basic principles of power supply design. What are the key components of a power supply?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- Energy-saving motorcycle rectifier regulator
- LED Driver ZD1680
- Miniature polarity reversal power supply using MAX1721
- A simple positive and negative power supply circuit
- Circuit diagram explanation: simple switching power supply circuit diagram
- About the real-life application of Silicon Labs’ new isolation smart switch
- Photosensitive automatic dimming desk lamp circuit and principle
- Circuit diagram of using photoelectric coupler to make mobile phone call reminder
- What’s so magical about the main circuit inside the inverter?
- Humidity detection circuit schematic diagram
- Two-channel low-power amplifier circuit
- Detailed explanation of audio preamplifier circuit
- mini stereo amplifier
- About the three-phase power grid measurement interface circuit diagram
- Capacitance measuring instrument circuit
