Capacitance measuring instrument circuit
Source: InternetPublisher:消失的歌 Keywords: Measurement power supply and other power circuits Updated: 2021/05/02
![Capacitance measuring instrument circuit](http://www.eeworld.com.cn/circuit/upload/28217ca159248264c97da5fc9e450b4f/0d97ff9af330cf4c5d0307c16e8e2293.jpg)
This measuring instrument can measure capacitance from several pF to 0.1uF, and the range is divided into five levels: 25pF, 100pF, 1000pF, 0.01uF and 0.1uF. Since the measurement principle is linear, it can be read directly using the ammeter scale.
When VT4 is turned on, the measured capacitor Cx and diode VD discharge. When VT4 switches once, the measured capacitor is charged and discharged once. The capacitance being measured is large, and more electricity passes through the ammeter each time it is charged; in addition, VT4 switches more times per second, and more electricity passes through the ammeter per second. The amount of electricity passing through the ammeter per second is the current flowing through the ammeter. Therefore, the current through the ammeter is proportional to the capacitance being measured, and proportional to the switching frequency of VT4. If the current passing through the ammeter is required to be the same, then the switching frequency of VT4 must be higher when measuring small capacitors.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Single-power supply circuit for ISO122P/ISO124
- Charging control circuit made by solar energy
- A small and easy-to-make fast charger
- Integrated regulated power supply with continuously adjustable output voltage
- Converting a lithium battery charging board into a constant voltage and current charger
- Mc34063 MP3 Switching Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- About the real-life application of Silicon Labs’ new isolation smart switch
- Photosensitive automatic dimming desk lamp circuit and principle
- Circuit diagram of using photoelectric coupler to make mobile phone call reminder
- What’s so magical about the main circuit inside the inverter?
- Humidity detection circuit schematic diagram
- Two-channel low-power amplifier circuit
- Detailed explanation of audio preamplifier circuit
- mini stereo amplifier
- About the three-phase power grid measurement interface circuit diagram
- Capacitance measuring instrument circuit
