Multifunctional conductivity tester circuit
Source: InternetPublisher:司马缸砸光 Keywords: Power supply protection Updated: 2021/07/03
![Multifunctional conductivity tester circuit](http://www.eeworld.com.cn/circuit/upload/1586d4c4925e7ec4ebf1cfdb35cd4114/79f058d26ad89288693f6b3768c743ff.jpg)
The circuit of the multifunctional conductivity tester is composed of a detection electrode, a resistor divider, a buffer circuit and a two-color diode, as shown in the figure. The detection electrode can sense the resistance of the object being measured, and control the two-color light-emitting diode to emit light according to the resistance of the object being measured. When the detection electrode senses that the resistance of the object being measured is greater than 300kΩ and less than 1000kΩ, the green indicator light turns on; when it senses that the resistance of the object being measured is less than 300kΩ, the red indicator light turns on, making the two colors synthesize into an orange-red light; when it senses that the resistance of the object being measured is greater than 1000kΩ , the two-color indicator lights VL3 and V⒕ do not light up. Adjusting the potentiometer RP can change the sensing range of the detection electrode.
- Benefits of Wide Bandgap Technology for Power Converters
- Step-down power supply for driving relays
- Basic connection circuit of signal and power supply composed of ISOll3
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Constant current LED lamp driver circuit with soft start and anti-shock
- Detailed explanation of 5v charger circuit diagram
- Principles and precautions of active discharge circuit
- A novel and practical DC low voltage stabilized power supply
- Production of backup power supply for cordless phone
- Homemade Electric Bike Fast Charger
- Importance of Voltage Supervisors and Output Topology Selection
- Asynchronous motor protection circuit composed of photoelectric coupler
- Typical Reference Voltage and Power Supply Circuits
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Recording level power supply circuit
- audio power circuit
- Single LTC power circuit
- Neon light high voltage power supply circuit
- 5V, 7.5V, 48V power circuit
- 6.3V, 270V, 300V DC power supply circuit
