A frequency meter circuit diagram composed of CD4046
Source: InternetPublisher:奥特man123 Keywords: Circuit diagram frequency meter CD4046 Updated: 2021/05/25
CD4046 is a general-purpose CMOS phase-locked loop integrated circuit. It is characterized by a wide power supply voltage range (3V-18V), high input impedance (about 100MΩ), and low dynamic power consumption. The power consumption is only 600μW when the center frequency f0 is 10kHz. , is a micro-power device.
The frequency meter uses the needle to indicate the level of the frequency being measured. R1 is composed of a 47k fixed resistor and a 51k potentiometer connected in series. R4, R5 and C4 form a low-pass filter. R3 is connected in series with the meter M and serves as the load of the source follower. R3 is also used to adjust the full-scale current of the meter. There is a large capacitor of 100LF on the meter head, which is used to eliminate the jitter of the meter needle at low frequencies. The measurement range of this frequency meter is 20Hz~1kHz.
The following is a frequency meter circuit diagram composed of CD4046 released by Shenzhen Jieduobang PCB Circuit Board Company .
![A frequency meter circuit diagram composed of CD4046](http://www.eeworld.com.cn/circuit/upload/042757abd454b655b8f63b7e50704555/7fe1644cdbe17d81328ef167e13203ed.jpg)
- In-depth analysis of DC-AC converter inverter
- Basic circuit description of adjustable voltage regulator LM317
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Driving circuit that controls LED brightness using PWM signal
- Principles and precautions of active discharge circuit
- Current/voltage conversion circuit using current converter
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- 0.7~24V continuously adjustable current limiting power supply
- Practical constant current charger-----Constant current charger
- Design of adjustable DC stabilized power supply circuit module
- Power circuit b composed of intelligent thyristor modules
- Industrial product promotion and shopping guide DC power supply circuit
- Portable device charging power circuit design
- Output 12V-10A power supply circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- Simple dual-channel variable DC power supply circuit
- Household emergency power circuit
- Nine-speed adjustable DC power circuit
- Small power UPS power circuit and production
