Easy to make negative ion generator circuit
Source: InternetPublisher:黄土马家 Updated: 2021/06/11
The following is a circuit diagram for a simple negative ion generator circuit.
The simple negative ion generator increases negative ions and has the effects of hypnosis, antiperspirant, analgesia, increase appetite, refreshing people and eliminating fatigue.
The picture shows the circuit diagram of the negative ion generator. The 220V AC mains power is rectified by D1 and then charged to C3 and C2. When C2 is charged until the neon bulb is turned on and triggers the SCR to turn on, C3 is discharged by the SCR and L1 of B. After being inducted and boosted by B, it is reversely rectified by D2. The 8kV DC high voltage is obtained to ionize the molecules of the generator M to produce negative ions.
Adjusting the resistance of R3 can change the trigger frequency and output voltage. Safety must be paid attention to when adjusting, and the power plug needs to be unplugged to replace components.
- Share an insect repellent circuit
- Two common RC oscillator circuits
- Practical method of making RC sine wave oscillator
- Basic connection circuit of HA-5340 in the same phase unity gain mode
- A relatively complete ultrasonic generator circuit
- Complementary symmetric astable multivibrator circuit diagram
- 1MHz crystal calibrator
- Magnetic pendulum oscillation circuit
- Franklin push-pull reactive voltage controlled oscillator
- Accurate reference clock oscillator circuit
