Share an insect repellent circuit
Source: InternetPublisher:风向西瓜 Keywords: circuit diagram pll oscillator circuit Updated: 2024/12/17
This insect repellent circuit will effectively repel insects such as mosquitoes, flies and cockroaches from your home or yard. The circuit uses specific frequencies to interfere with the insects, so the insects stay away from the circuit.
This insect repellent circuit can be placed inside the home or outside (for speakers). If you want to place the entire circuit outside the house, make sure the circuit is in a safe place, especially when it rains.
This circuit consists of a PLL (Phase Looked Loop) oscillator circuit using a CMOS 4047 with a frequency of 22 KHz. The current consumption is about 120mA. Therefore, it is recommended to use an external power supply for better results.
- Practical method of making RC sine wave oscillator
- Varactor diode frequency modulation oscillation circuit
- Composition diagram of transformer feedback LC oscillator circuit
- 60Hz time base signal generating circuit
- AD585 applied to A/D conversion system circuit
- Field effect transistor RC bridge oscillation circuit
- 1MHz crystal calibrator
- Deformed capacitive negative feedback sawtooth wave circuit
- Application circuit of operational amplifier in signal generator
- Infrared transmitter circuit using silk screen quartz crystal oscillator
- Crystal oscillator circuit composed of several gate circuits d
- Low phase noise voltage controlled oscillator circuit a
- Improved multivibrator circuitb
- Adjustable frequency Wien bridge oscillator circuit
- Low frequency swing oscillator circuit
- Simple voltage controlled oscillator circuit
- Transistor self-excited multivibrator circuit
- YELP oscillator circuit diagram
- Low power consumption, 5V drive, temperature compensated crystal oscillator circuit
- PLL FSK demodulator
