Pressure signal conditioning circuit circuit diagram based on MAX1450
Source: InternetPublisher:走马观花 Keywords: Circuit diagram signal conditioning circuit MAX1450 Updated: 2021/06/15
Signal conditioning: It is a signal processing circuit that converts analog signals into digital signals for data collection, control processes, calculation display readout, or other purposes. Analog sensors can measure many physical quantities, such as temperature, pressure, light intensity, etc... However, since the sensor signal cannot be directly converted into digital data, this is because the sensor output is a rather small voltage, current or resistance change. Therefore, when converted into The digital signal must be conditioned beforehand. Conditioning is the process of amplifying, buffering, or scaling analog signals to make them suitable for the input of an analog-to-digital converter (ADC). Then, the ADC digitizes the analog signal and sends the digital signal to the MCU or other digital device for system data processing.
- Schematic diagram of car cigarette lighter to USB power port
- Introduction and principle analysis of switching regulated power supply
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Parallel DC regulated power supply circuit diagram
- How to use SBR to improve power conversion efficiency
- Adjustable voltage power socket
- Practical constant current charger-----Constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Excellent performance household inverter power supply circuit
- Laser power circuit
- Highly integrated analog front-end signal conditioning circuit diagram
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- Power supply circuit with multiple outputs (MAX1902)
- CF1 (CF2) DC power supply circuit
- led drive power circuit
- Household emergency power circuit 02
- ±5V, ±12V power circuit B
