Highly integrated analog front-end signal conditioning circuit diagram
Source: InternetPublisher:天天都吃好吃的 Keywords: Circuit diagram analog front end signal conditioning circuit high integration Updated: 2021/07/05
The circuit shown in the figure below is a complete and highly integrated analog front-end industrial-grade signal conditioner that utilizes a 16-bit differential input PulSAR ADC to digitally convert ±10 V industrial-grade signals. This circuit uses only two analog components to provide a high-impedance instrumentation amplifier input, level translation, attenuation, and differential conversion with high common-mode rejection (CMR) performance. Due to its high level of integration , this circuit saves printed circuit board space and provides a cost-effective solution for common industrial applications.
In process control and industrial automation systems, typical signal levels are up to ±10 V. Signal inputs from sensors such as thermocouples and load cells are smaller, so large common-mode voltage swings are often encountered, This requires flexible analog inputs that can handle small and large differential signals with high common-mode rejection while having high impedance inputs.
![Highly integrated analog front-end signal conditioning circuit diagram](http://www.eeworld.com.cn/circuit/upload/2766d67de15f30513f3f936a580b91ba/6680aa5198b43411487cf41bd21dfed7.jpg)
- Analysis of the working principle of switching regulator
- In-depth analysis of DC-AC converter inverter
- Using Lead-acid Battery as Power Source for Walkman
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Adjustable regulated power supply with current limiting protection
- CNC regulated power supply production
- Car Audio Power Supply
- Practical constant current charger-----Constant current charger
- MAX1811 Lithium Battery Charger Production
- LM317T voltage regulation adjustable circuit diagram explanation
- Design of adjustable DC stabilized power supply circuit module
- Pressure signal conditioning circuit circuit diagram based on MAX1450
- DC 12V to AC 100V inverter power supply circuit design
- Solar power circuit
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Simple dual-channel variable DC power supply circuit
- Inverter power circuit made with BJ50A
- Telephone power circuit
- 25Hz ring current power supply circuit
- Small power UPS power circuit and production
