Use 555 to form an additional circuit for measuring voltage with a frequency meter
Source: InternetPublisher:jikai233 Updated: 2021/12/14
As shown in the figure, this circuit consists of 555, an astable multivibrator composed of R1, RP1, and C1, and an attenuation resistor. As a voltage-frequency converter, it can measure DC voltages of 0~5V.
Potentiometer RP1 determines that when the input voltage is 0V, the frequency meter reading is 0Hz; RP2 is used to adjust the frequency meter reading to 50Hz when the input voltage is 5V, that is, full-scale adjustment. This additional circuit enables measuring frequency instead of measuring voltage.
- Integrated soldering iron with protection function
- Water Softener
- How solar cells work, some unique designs of solar cells
- A simple device activator circuit
- Mobile phone interference circuit sharing
- Using BMP280 to make a weather station
- How to Make a Buzz Wire Game Using Arduino
- Building a Dehumidifier for a 3D Printing Dry Box
- Simple and easy-to-make electronic mosquito repellent
- DIY Solar Detector
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
