Typical application circuit diagram of LED driver chip TPS6115
Source: InternetPublisher:傻阿乐 Updated: 2020/07/19
The picture above is a reference for buck-boost design. In daily product design, we often encounter fluctuations in power supply voltage. For example, the battery voltage before charging and after discharging is different, and it falls exactly in the middle of the forward voltage value of the LED that needs to be driven. This IC can solve this problem of voltage boosting and bucking very well!
Typical application circuit of LED driver chip TPS6115
- Designing Energy-Efficient Solenoid Drivers: Design Concepts
- How to construct a small welding machine using a 5 amp transformer and a high current bridge rectifier?
- How to build a light source that adjusts its brightness based on atmospheric conditions
- Share an electronic mouse repellent circuit
- How to use Tesseract for optical character recognition on Raspberry Pi
- Design of a drone wildlife counting system using FOMO object detection algorithm
- How to Make a Pet Robot
- Automatic recovery electronic fuse with soft start function
- Production of electric mosquito killer
- How to create image processing solutions using HLS capabilities
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
