Double-key touch switch circuit diagram using 555 time base circuit
Source: InternetPublisher:super_star Updated: 2020/07/09
The picture below shows a double-key touch switch and a single-key touch delay switch made using a 555 time base circuit. M1 in the picture is the "on" touch chip. When a human hand touches it, the clutter signal induced by the human body is added to the ② pin of the low-level trigger terminal IC of the time base circuit. The circuit is set, and the ③ pin outputs a high level, and the relay K is electrically closed, its normally open contact is closed, and the controlled electrical appliance is powered on. M2 is the "off" touch piece. Once touched, the clutter signal induced by the human body is added to the threshold terminal IC⑥ of the 555, the circuit is reset, pin ③ outputs low level, the relay loses power and trips, and the controlled electrical appliance stops working.
Double-key touch switch circuit made using 555 time base circuit
- Monostable trigger timing circuit
- Using NE555 to delay the output of high level circuit
- Design and production of a high performance compressor voltage stabilizer delay device
- 555 transformerless DC/I)t2 positive voltage output circuit
- 555 infrared transmitter circuit
- 555 bipolar power conversion circuit
- 555 voice-activated duty alarm circuit
- 555 infrared sound and light alarm circuit
- 555 voltage controlled oscillator circuit using Vc terminal to control duty cycle
- 555 miniature cardiac defibrillator circuit
- NE555 time base integrated circuit diagram
- 50% duty cycle 555 circuit
- Self-stopping hypnotic device circuit diagram
- Double-key touch switch circuit diagram using 555 time base circuit
- Pulse width modulation circuit diagram based on 555 base time
- Electric bell sound delayer schematic diagram
- Integrated circuit timer 555 internal structure circuit diagram
- Circuit diagram based on 555 base time astable working mode
- 555 long learning time reminder circuit
- 555 Electronic disinfection circuit using ozone tube
