Using NE555 to delay the output of high level circuit
Source: InternetPublisher:supremeOne Keywords: NE555 delay circuit Updated: 2024/10/17
The power-on delay output high level circuit is shown in the figure below. When the power is turned on, since capacitor C has no time to charge, pins ② and ⑥ of the 555 time base circuit are at a high level, and pin ③ outputs a low level. As capacitor C charges, the potential of pins ② and ⑥ of the 555 time base circuit decreases. Until the potential of pin ② is lower than 1/3 Vcc, the circuit state flips, and pin ③ changes from a low level to a high level and remains so. The power-on delay time tw=1.1RC. The diode VD in the circuit is set to discharge capacitor C after the power is turned off. This circuit is generally used to control the delayed connection of high-voltage power supplies or control the delayed connection of other power supply circuits, so this circuit is also called a power-on high-voltage delay circuit.
- Several major features of 555 integrated time base circuit
- 555 infrared transmitter circuit
- 555 bipolar power conversion circuit
- 555 light control and infrared sensor energy-saving lamp circuit
- 555CO gas leak alarm circuit
- 555 high power sweep siren circuit
- 555 Electronic Scarecrow Circuit
- 555 color changing electronic corsage circuit
- 555 fluorescent lamp group centralized rectification and starting circuit
- 555 hours-long adjustable timer circuit
- Assembly line outage monitoring circuit
- Very simple voltage multiplier circuit block diagram
- Long delay circuit using integrated circuit 5
- Delay circuit two using 555 time base integrated circuit
- Light-controlled street light circuit using NE555 (1)
- Use NE555 to make a three-way lantern controller
- Water tank automatic water supply control circuit
- Clever use of NE555 as a cycle timer circuit with adjustable on-off time
- Control circuit using NE555 integrated circuit_1
- DC voltage polarity converter circuit diagram composed of NE555
