Simple triangle wave to sine wave circuit diagram
Source: InternetPublisher:蓝猫淘气 Updated: 2021/04/05
This circuit uses op amp uA741 to generate a sine wave with variable frequency. It is more difficult to generate a sine wave with variable frequency than a square wave with variable frequency. This circuit can convert positive and negative triangle waves into sine waves. The circuit is shown in the figure. Working principle: This circuit is actually an amplifier whose gain changes inversely proportional to the output voltage amplitude. Two 10k ohm potentiometers RP2 and RP3 set the slope of the output voltage near zero crossing. When the output voltage increases, RP3 should be adjusted until the diodes VD3~VD6 begin to be forward biased. In order to get the top of the smooth change of the sine wave, the potentiometer RP1 should be adjusted carefully, and the diodes VD1 and VD2 should be carefully selected. Use a dual-trace oscilloscope to observe the input and output, and carefully adjust RP1, RP2 and RP3, so that the circuit can be adjusted to the best state. The main disadvantage of this circuit is that it only works optimally when the input is 1.4V peak-to-peak.
- How to build a light source that adjusts its brightness based on atmospheric conditions
- Share an electronic mouse repellent circuit
- How to convert digital values into analog values by connecting MCP4725 with Arduino
- How to implement semaphores and mutexes in FreeRTOS using Arduino
- How to Make a Buzz Wire Game Using Arduino
- Design of a drone wildlife counting system using FOMO object detection algorithm
- Making a Smart Blind Pole Using Arduino Uno and Ultrasonic Sensor
- Share a fire sensor solution using MLX90640
- How to Use the Radio to Record Phone Calls Automatically
- A novel resonance demonstration device
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
