Hearing aid, hypnosis, memory enhancement multi-purpose machine circuit diagram
Source: InternetPublisher:王达业 Keywords: Machine circuit diagram headphones Updated: 2020/02/24
This three-purpose machine has a simple circuit, is easy to make, and does not require debugging. It has certain practical value and is very suitable for amateur production.
working principle
The electromechanical principle is shown in the figure. It consists of a CMOS six-inverter. A-D form an odd-stage negative feedback amplifier. R1 is a feedback resistor . Adjusting the ratio of R2 and R1 can adjust the voltage gain, and its typical gain can reach 100 times. F3 and F4 are connected in parallel to enhance the load capacity of the amplifier. E and F form a low-frequency signal generator, which is the simplest CMOS multivibrator. Its oscillation frequency is approximately 0.7Hz. Changing C2 or R3 can change its oscillation frequency. R4 and M IC form a pickup circuit.
When used for hearing aid and memory enhancement applications, switch S is placed in the 1 position, and the MIC converts external sounds into electrical signals, enters the amplifier for amplification, and is then output by the headphones . When doing memory enhancement, listening with a pair of headphones can reduce external interference.
When using the hypnotic device, put the switch S in the 2 position, and the 0.7Hz low-frequency signal is amplified by the transformer. A "click-click" sound can be heard in the headphones, similar to the sound of rain, which makes people relax and relax. Have a hypnotic effect.
Component selection and production
The components list is as follows. No. Name Model Quantity R1 Resistor 10M 1/8W 1 R2 Resistor 100K 1/8W 1 R3 Resistor 1M 1/8W 1 R4 Resistor 2K 1/8W 1 C1, C2 Electrolytic capacitor 1u/16V 2 IC COMS six inverter CD4069, C033 , C003, C063, CC4069 1 M IC microphone small electret condenser microphone 1 CZ1, CZ2 headphone socket 2 The power supply can be selected between 4.5-9V, and can be powered by a laminated battery.
- Production of two-color music lantern
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- Design plan of crop disease detection system based on edge artificial intelligence
- Four water tower control schematic diagram
- Electronic mousetrap circuit
- Nine-digit key code lock circuit
- HTS fire alarm
- CNC machine tool display circuit
- Low cost alarm circuit
- Light controlled electronic bird circuit
- Simple telephone intercom circuit diagram
- Homemade small telephone program-controlled switch circuit diagram
- JFET-MOSFET headphone circuit diagram
- Fangcheng SG260-A food juicer, blender circuit diagram
- Bit brand fully automatic soybean milk machine circuit diagram
- Yijia brand CJX-150A thousand-wing turbine range hood circuit diagram
- Macro YPF5-4 range hood circuit diagram
- Yichang WJ-18E heater circuit diagram
- Smet RL-175D storage cabinet type warm water dispenser circuit diagram
- FOTILE FYB-T2 intelligent hot and cold water dispenser circuit diagram
