Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
Source: InternetPublisher:王达业 Keywords: LEDs Micropython Updated: 2024/12/19
In this tutorial, we will use Micro Python to control two LEDs via multithreading with dual-core programming on a Raspberry Pi Pico .
So far, we have seen how to connect OLED, LCD, Servo, Ultrasonic Sensor and we have implemented I2C, ADC, Bluetooth communication with Raspberry Pi Pico . The RP2040 microcontroller pico board has dual cores. If you are not familiar with multithreaded execution, then think of your computer system. It can execute multiple programs at the same time which can be run by an operating system using multithreading. But we don't have any operating system on Raspberry Pi Pico to control the CPU cycles, it can only support one thread per core, in this case two.
Components required for dual-core programming on the Raspberry Pi Pico
You will need to make sure you have the following components to demonstrate dual core programming on the Pico board.
Raspberry Pi
LED x2
Resistor x2 (330 ohm)
Breadboard
Connect the wires
Servo Motor Circuit Diagram using Raspberry Pi Pico Board
The circuit diagram of the servo motor is as simple as this. I have connected two LEDs using two 330 ohm resistors with GPIO15 and GPIO16 respectively. The ground pin of the LED has been connected to the ground pin of the Pico board.
Multithreading on the Raspberry Pi Pico using dual-core programming
You need to clone our Raspberry Pi Pico Tutorials GitHub repository. Then open the "T9_DualCore_Prog ram_PIco" folder. In this folder, you can find the "code" folder. Open the "main.py" python file in the Thonny editor. Now, let's discuss the main.py file.
Imported from machine Import u
First, we need to import the Pin() class from the machine.py library mentioned above. We have used the machine library several times in our previous tutorials and hopefully you are familiar with it by now. Then we need to import the "utime" library to use the internal clock of the pico. We are using the "_thread" library to use the threading functions made by the raspberry pi pico community.
led1 = Pin(16, machine.Pin.OUT) led2 = Pin(15, machine.Pin.OUT) sLock = _thread.alloca
In the above code, I initialize the two LEDs of GPIO15 and GPIO16 as OUPUT using the "Pin(16, machine.Pin.OUT)" and "Pin(15, machine.Pin.OUT)" functions. The "_thread.allocate_lock()" function can be used to provide a semaphore lock for two threads. If you want to know more about this function, you can refer to the documentation of the "_thread" library.
Define the core task(): And true: sLock.
We will use the "CoreTask()" function in another kernel in a single thread. In the while loop inside the function, we use a semaphore lock to hold the thread until it is finished. I then turn led2 high for 1 second and then print the instructions on the output of Thonny. I then release the semaphore lock when the thread is finished. The "_thread.start_new_thread(CoreTask, ())" function will start the thread. This function takes the target function name as the first argument. In my case, it is "CoreTask" and it accepts arguments in the second argument. In my case, I don't have any arguments to pass.
And true: # We acquire the semaphore lock sLock.acquire() print("Entering the main thread") led1.toggle() utime.sleep(0.15) print("Led 1 starts switching.") print("Exit main thread") utime.sleep(1) # We release the semaphore lock sLock.release()
In the while loop above, we have similarly used another semaphore lock so that the main thread continues to run until it is finished. It will toggle led1 and then release the semaphore lock. Now, in Thonny IDE, open the "main.py" file. First, save the "main.py" file on your Pico board by pressing the "ctrl+shift+s" keys on your keyboard. Before saving the file, make sure your Pico board is connected to your laptop . After saving the code, a pop-up window will appear as shown in the figure below. You must first select the Raspberry Pi Pico and then name the file "main.py" and save it. This process enables you to run the program while the Pico is open.
When you upload and run the code on Pico board, you will see led1 connected to GPIO16 toggles with a delay of 1.15 seconds. But led2 connected to GPIO15 blinks with a delay of 2 seconds. You can refer to the video below for more details.
Main File
Imported Machine Importing utime import_thread led1 = machine.Pin(16, machine.Pin.OUT) led2 = machine.Pin(15, machine.Pin.OUT) sLock = _thread.allocate_lock() Define the core task(): And true: sLock.acquire() print("Enter the second thread") utime.sleep(1) led2.high() print("Led 2 is on") utime.sleep(2) led2.low() print("Led 2 is off") utime.sleep(1) print("Exit from the second thread") utime.sleep(1) sLock.release() _thread.start_new_thread(CoreTask, ()) And true: # We acquire the semaphore lock sLock.acquire() print("Entering the main thread") led1.toggle() utime.sleep(0.15) print("Led 1 starts switching.") utime.sleep(1) print("Exit main thread") utime.sleep(1) # We release the semaphore lock sLock.release()
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- DIY an electromagnetic levitation device
- What are the challenges in designing a permanent magnet linear generator?
- Introduction to the internal structure of the Delta winding motor
- A small improvement to the temperature and water level indicator alarm
- Working principle of one Xipu STR soft starter controlling two motors
- Using P110C to control 6 DC motors simultaneously
- Guanghua brand anti-theft doorbell electronic lock circuit
- Homemade short circuit alarm device
- Ultra-short wave item left behind reminder alarm
- Application circuit diagram for driving 5 white LEDs
- SG1524 driver LED circuit
- LED constant current source circuit diagram using LM317
- High battery life LED circuit based on GEC8310
- Three-phase phase loss alarm light circuit
- PWM brightness adjustment circuit diagram
- A simple DC LED driver circuit
- Three-phase alternating current detection circuit
- Industrial static elimination circuit
- 4 and 1/2 LED digital display (DMS-40PC series)
