High-loudness alarm sound generator circuit design
Source: InternetPublisher:红水杯 Updated: 2021/07/27
Working principle of the circuit: This circuit is mainly composed of the sound-generating integrated circuit KD~9561 and the switching integrated circuit TWH8778. When working, the KD-9561 outputs the alarm signal, which is processed and amplified by the TWH8778 high-current switching integrated circuit to push the speaker to emit a loud alarm. Voice. The IC uses KD-9561 sound IC, or you can choose KD-9562 sound IC, and wire it according to the requirements to make it sound the alarm signal. IC2 uses the TWH8778 switching circuit. When the power supply voltage is 12V, the speaker BL should choose a speaker of 8Ω and above 3W or a special horn-type speaker. The resistance of the current limiting resistor R1 is 300Ω~510Ω. D2 uses a 3V voltage regulator tube. D1 is the circuit For protection diode, 1N4001 can be selected. After the circuit installation is completed, as long as the wiring is correct, it can generally be used normally without debugging.
- Integrated soldering iron with protection function
- How to construct a small welding machine using a 5 amp transformer and a high current bridge rectifier?
- Share a project that controls the mouse pointer by moving the index finger
- Building an open source dynamic light scattering device
- DIY an open source air quality monitor
- How to make a clock Bluetooth IOT speaker using Arduino
- The production principle of high voltage self-defense flashlight and electric stick
- Electronic fly killer
- Production of wake-up device
- Production of electric water bottle energy saver
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
京公网安备 11010802033920号
