Excellent performance two-channel subwoofer circuit
Source: InternetPublisher:走马观花 Updated: 2010/06/19
Circuit principle: The input signal is processed by a fourth-order low-pass filter composed of IC1-1 and peripheral components with a changing slope of 24db/oct (the value in the figure is fc=70Hz, A=8.2dB), and then is processed by IC2 The inverting AC amplifier centered at -1 performs 10 times buffer amplification and outputs it. The greatly enhanced low-frequency signal and the original signal are sent to IC2-3 by C4 and C3 respectively for mixing processing, and the mixed signal is output by C5. W controls the mixing amount of the low-frequency signal and the original signal. In order to ensure that the C5 output signal is 'original' when W is turned off, the gain of this stage is set to 0 dB. Component selection: The error of R and C, which determine the low-pass cutoff frequency, should be less than 1%. R2--R5 can be selected from resistors with an error of 5%, all of which use 1/8W RJ series; the non-polar capacitors use CL series, C4, C4 , C5 uses tantalum electrolysis; it is best to use a digital meter to select and test RC components, and use authentic TL084 for IC. When in use, just connect this circuit in series between the signal source and the power amplifier.
Latest Audio/Video Circuits Circuits
- Simple and practical small amplifier
- DIY 50W Gallstone Amplifier
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- The production of 6P14 small tube amplifier
- Using 6P15 to create an ultra-linear push-pull amplifier
- Electronic bird repeller for crops
- Typical applications of optocouplers in audio amplifier circuits
- Audio power amplifier circuit powered by a single power supply using LM1875
- Minimum output noise/reduced output power circuit using LM4910
- LMl876 is used to assist the audio power amplifier circuit
Popular Circuits
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
