Small FM transmitter circuit
Source: InternetPublisher:难得正经 Updated: 2013/01/28
Brief description: Here I will introduce to you a small FM transmitter that is simple and easy to make. It not only meets the requirements of the transmitting distance, but also can input sound signals using microphones and lines at the same time for background dubbing. The circuit also adds a modulation monitoring meter so that you can better control and use the transmitter. The circuit is as shown below. After a brief introduction, do you think it is like a set of equipment for a broadcast station? Circuit principle and component selection:
After the microphone picks up the signal, it enters the voltage negative feedback single-tube amplifier composed of BG1 and peripheral circuits through C1 coupling, which amplifies the weak voltage signal to a sufficient amplitude and enters together with the amplified line input signal of U1A U1B does the mixing. The mixed signal is passed through R17 to modulate the test ratio LC oscillator composed of BG2 field effect transistor and surrounding circuits. The test ratio LC oscillator is characterized by the simplicity of an ordinary capacitor three-point oscillator, and at the same time it has high efficiency and High stability. Good waveform and modulation bandwidth are particularly important for amateurs making FM transmitters. Finally, the post-stage amplifier made of BG3 is amplified and emitted outward through the transmitting antenna, and the broadcast can be listened to with an ordinary FM radio. The other signal is amplified by the amplifier composed of U1C and then rectified by D2 simple wave, and then driven by a DC microammeter to monitor the modulation amplitude of the signal. When using it, it is generally advisable not to exceed 85%. The integrated circuit adopts general-purpose quad operational amplifiers such as LM324 and forms a single power supply reverse input working mode, that is, the positive-phase input voltage is set at half of the power supply voltage. The monitoring meter is 200u type, and BG1.BG3 uses 2SC1815. BG2 uses 3DO2 field effect transistors, and D2 varactor diode uses 1S2267. The antenna is required to use 1/4 wavelength. If a rod antenna is used, it is best not to be less than one meter. Otherwise, the overdue launch effect will not be achieved. Finally, please do not interfere with normal radio broadcasts!
![小型调频发射机电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/47bd876e-3c63-11ec-a100-086126841eb8.jpg)
Latest Communication Circuits Circuits
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- What is the basic principle of parametric amplifier?
- TA7792 Medium Wave Radio Circuit Diagram
- Convenient and practical electric guitar wireless transmitter
- Design and Analysis of Half-duplex Intercom Circuit Using LM386
- Eight-way remote control transmitter circuit using CS901
- XE1203 FSK 915/868/433 MHz Transceiver
- TXl00 ASK 1 GHz~100 MHz transmitter module
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
Popular Circuits
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Fiber optic transceiver circuit diagram
- Square wave generation circuit
