USB communication circuit
Source: InternetPublisher:王达业 Keywords: Communication circuit USB communication PDIUSBD12 ATMEGAL6 Updated: 2021/08/29
The function of the USB communication circuit is to realize communication between the device side and the host side of the data acquisition system. This function is mainly implemented by the core microcontroller ATmega16 and the USB control device PDIUSBD12 . Among them, PDIUSBD12 is a chip that complies with the USB1.1 protocol and plays the role of a bridge between the device and the host in the USB communication circuit. The microcontroller ATmegal6 and the USB controller PDIUSBD12 communicate through an 8-bit parallel bus. The 8-bit parallel bus needs to connect 8 I/O ports on the ATmegal6 side. PDIUSBD12 integrates a clock multiplication PLL on-chip, and the crystal oscillator circuit uses a 6MHZ crystal oscillator and two capacitors from 2pF to 68pF. A 18 ohm matching resistor must be connected in series to the signal output terminals D+/D- of PDIUSBD12 . The communication circuit is shown in Figure 2.
![USB communication circuit](http://www.eeworld.com.cn/circuit/upload/4712531b54280ba926efe66da7d1230a/200647202ff44d5a6d13876d4616f7aa.jpg)
- Analysis of the working principle of switching regulator
- The basic principles of power supply design. What are the key components of a power supply?
- Energy-saving motorcycle rectifier regulator
- What kind of circuit is a voltage regulator circuit?
- Recommended circuits for different power on times of LM4911
- Use pulse width modulation to get a precise output voltage
- How to use SBR to improve power conversion efficiency
- Current/voltage conversion circuit using current converter
- Dual forward converter schematic diagram
- CNC regulated power supply production
- Importance of Voltage Supervisors and Output Topology Selection
- Design of adjustable DC stabilized power supply circuit module
- Excellent performance household inverter power supply circuit
- DC 12V to AC 100V inverter power supply circuit design
- USB communication circuit
- Warm current power circuit a
- Transistor stabilized current power supply circuit 2
- Super Class A power amplifier power circuit
- led drive power circuit
- DC power supply circuit for semiconductor radio
